Help need immediate help
okay i have lg g2 802 international and won t boot and won t enter download mode and recovery... he is stucked in fastboot(it leads me to fastboot when i open it) and the laptop won t recognize it
here s is picture
oky now the laptop recognize fastboot and i wrote reboot fastboot and it rebooted
Provided you have a d802, you can use these partitions:
http://downloads.codefi.re/autoprime/LG/LG_G2/D802/Stock_Firmware/10b_16G_partitions
Fastboot flash aboot, boot, dbi, laf, rpm. sbl1. and tz. First place files into sdk-tools folder. You may want to rename the partitions to remove the numbers/dashes at the beginning of the filenames to lessen confusion.
fasboot flash aboot aboot.img
fastboot flash boot boot.img
etc
etc
etc
...for all 7. Then disconnect phone from pc. Long press power for no less than 15 seconds to power off. Then press and hold volume up while at the same time plugging back into pc. You should have download mode now. Then you can restore using tot/kdz.
