please help! 3g uploading/downloading always on, synching non stop and making my battery warm or hot! happy to mail a $20 bill to an address of your choice, a p.o. box, etc. (private message me) for someone who can 100% fix this with a simple, easy solution.. i am not a developer and need an easy fix, please.
just rooted a week ago. i used "titanium pro", "superuser elite", and "busybox installer pro". in my home, using a 3g microcell, my 3g icon is lighted up, lit up, turned on, activated, active, and always receives, is receiving, sends, is sending, uploads, is uploading, downloads, is downloading, synchs constantly, and does not turn off!
i deleted every sincle crap samsung and at&t app.
i like and use "daily briefing", but i have force closed it, frozen it and removed it from my screen, with no luck. before rooting, the upload/download arrows would come alive when i manually updated daily briefing for weather and ap news, but it would stop when i was non rooted. now it uploads/downloads constantly, and won't stop synching.
i use "program monitor", which is a samsung widget that turns different colors depending on ram/cpu demand, and the calendar widget which shows the next days google calendar events. yes, i have forced closed them, removed them from my screen, and i have frozen them in titatinium pro. i have also frozen market in titanium pro, but no luck. i have forced closed everything possible....
THE 3G ICON IS LIT UP AND ACTIVE, SHOWING UPLOAD, UPLOADING, DOWNLOAD, DOWNLOADING RECEIVING, RECEIVE, SEND, SENDING, SYNC.
BOTH THE 3G UP AND DOWN ARROWS ARE TURNED ON, WITH A SOLID OR SOMETIMES A DIM RED/GREEN, OR BOTH RED AND GREEN ARROWS ON. THIS NEVER HAPPENED BEFORE I ROOTED A WEEK AGO.
i have gone onto quick app cache manager and forced closed literally everything i can think of, except apps that are needed to run my phone.
i have moved every possible app to sd card, via titanium pro when it allows to move "to external sd card". no, i have not done anything special, like create a rom, force to market, remove from market, bla, bla, bla, or anything fancy. i ONLY wanted to root for the pleasure of murdering 99.999% of the bloatware, which i have. i do NOT want to sideload, create a rom, whatever the hell that is, or anything fancy, period.
any ideas? YES, i have googled and searched for an hour for this issue, and on this forum, and have not found an answer.
i am a rooted 2.2 froyo at&t android samsung captivate.
in case i get several answers, i need, please, the simpliest, easiest method to fix this, and will go with the BEST and easiest answerer to send the $20. i wish i could send $20 to everyone, but i suppose you will need to trust me.. the person who gets the $20 will hopefully be honest and post i did in fact send it to them.
thanks..
thanks..
