Help Oplus Xonpad tablet. Help for swelled battery.
umby75
Hi, i have the tablet in subject and i have a serious problem because my battery is swelling but i don't kniw how can i reokace my battery and which battery is fine for replacement.
I don't find guidelines about my tablet and i don't know which guide for tablet i can follow to solve my issue.
Thank you for replies..
Contact Oplus tech support IMO. Don't think there's much other info available for this device, other than it's for the Indian market.
FYI a swelling battery can actually be very dangerous. So I would advise you to stop using it immediately.
I've already contacted the Service Center but i can only send the tablet to India and doesn't suit me.
Then I'm looking for a way to replace the battery using a right guide that come from other devices.
I know i.e. that there are tablets with Asus brand and models identical the Oplus brand tablet...
Thank you for you advise but I don't use the tablet for much time.
Take the battery out now... If it does go bad, it will go bad very quickly, may suddenly go bang/catch fire/spew toxic chemicals before you have a Chance to react.
Its just not worth the risk.
After its out you can work out how to replace it.
I've not used the battery for much time.
The point is that i don't know how i can open the device to remove the battery.
