markasherman
I just did the old batter check, as I have been very disappointed with my battery. You see, I will have to plug the phone in before the end of the day (about 10 hours), after having it at a full charge in the morning. Throughout the day, it receives little, to moderate use for texting and calls or the occasional email. I will use it for little bit to surf the web when I have down time and the like. But really, I don't use it as heavily as I would like because I can sit and watch the battery level go down.
Regardless, I just checked my battery usage, and the OS is eating it, more than the display. Just sitting on the counter, the OS is consuming over 50% battery use, the display, 21%. I constantly back out of apps after using them, or exit if there is an option. I had a task killer on my original MyT, but have been told not to use one on this phone; however, if the OS is what is eating my battery, I fear I may have no other option.
Any suggestions out there? What can I do to get at least a day's use out of the phone without having to charge it.
My thanks for your insights and thoughts.
