Root Over clocking 1612mhz ???
Hey all I have read the rush is 1000mhz rated but when using CPU Control it says max 1612???? :confused::confused: so is that possible or did I read it wrong about the 1000mhz ...and is it safe.... I set my min value between 921 and 1024
Thanks :thumbup::thumbup::D
Many custom kernels have the ability to over clock above the stock clock speeds.
Use caution going above the stock speeds, as it creates more heat and can cause instability
