Bennyboy784
I have a nexus 5 with Android 5.0, I have root and I'm experiencing overheating all the time, even when I'm just browsing the internet without any other apps open... Help is appreciated
What root-enabled apps do you have installed? Are you on an otherwise-stock ROM and kernel?
Also:
1. What is your signal strength when this is occurring? (Settings -> About phone -> Status -> SIM status -> Signal strength (the lower the number, the better))
If your device is constantly searching for a network signal, it could be working extra hard.
2. Do you have your N5 in a case? (I've got one of the Google cases that completely surrounds the phone)
My phone gets a little warm during long-ish (10+ minute) phone calls that I attribute to also having it in a case.
Lots of battery temperature apps out there you can use to see the temp:
https://play.google.com/store/search?q=battery temp&c=apps
yeah i have an all-surrounding case, Signal strength is at -102 dBm 41 asu
