Help Pantech Burst battery drains faaassssstttt
lalabluee
What is wrong with my phone? In 45 mins the battery went from 50% to 11%? I was asleep and no apps or any thing on the phone was being used. I tried charging it but it took about 30 mins to charge from 4% to 6%. Also, my mom has the Pantech tablet that came in the phone deal (forgot the name -__-) and i tried using her chager that outputs 2A and it charged a lot quicker. My charger is a 1A. What's going on? Is it the phone or battery or charger? Help pleaasseee.
try charging through PC and see if it work properly
if yes then your phone battery is good and the problem is with charger
now there are 2 possible senario
1 - cable is faulty ... try charging with another cable [friend etc...]
2 - battery fault
Hello welcome to the forum I see you have a problem with your pantech. Well if the battery has a problem. Is your device rooted. Next thing try and and reset the device. This will erase the battery stats to a fresh start. Now after wiping the stats clean get the app juice defender from the market.
son had same problem but finally enabled power saver app on phone /settings and especially keep the wifi set to OFF. That was causing phone to constantly look for wifi connection while rapidly draining the battery as a result.
My phone is not rooted and I want to root it but when I connect my phone to my PC it'll show debig mode and USB connected select to copy file .And I can select USB storage and copy files but when I open kingo it'll show no device connected I've tried 100% but stil same thing and when I wnt root with poot app the fone will freeze and get heated
