Help Pattern lock disable doesn't work.
ABIRDEGG
Rooted moment... I put the grid pattern screen lock on . I see where to disable, however it does not allow to turn off.. is pain in the anxiety dept!! Some one please help me. Much thankful!! :):D
It is not a fix to use the no lock apps.. there is NO way to remove the check out of the require pattern box! Thanks again!
press menu ->setting-> location & security-> and then uncheck the require pattern lock. it'll ask you to put the pattern lock in again to confirm and that should do it
