zuben el genub
Extreme Android User
Rooted Nexus 4 - just installed CM 11.
There is absolutely no volume on phone for calls, callee's phone rings, but I can't hear the ringing, and the callee can't hear me.
Checked out all the sound on the phone. The phone recorder works, I have a baseball app that shows video highlights, sound plays, mp3s play. Ringtones work.
It has to be the phone itself.
After installing CM11, I looked at available networks for TMobile. Metro PCS LTE was preselected. It's the first in the list - so is that the default or does the phone think I'm on LTE? There is no selection for GSM/HSPDA which I have. I can use the regular TMO APN, but no sound in calls. The other phone spec is UMTS.
I can send and receive texts, so I don't think it's TMO, unless they have updated towers to LTE. I notice 2G says no service, and TMO was repurposing 2G for LTE.
Google hasn't messed with the contact list, have they? I mean that if you don't sync, you don't call. I noticed that contacts appeared in Google on the PC after I installed CM and GAPPS. I didn't have any there.
