chickflick
Hi!
This is my first Android phone, so I just have a couple of settings questions, hopefully someone can help!
I tried to set it to vibrate for calls and text messages, and especially when the screen is turned off, it doesn't do it. It seems like the only options are ring or silent. Anyone know?
My other question is, I was wondering if there was a way to get all the apps I download to automatically DL to the SD card? My phone ran out of space right quick, but there's tons of space on the SD card. I tried moving them, which seemed to work for some of them, but there are still apps I'm not allowed to move, and I want them to automatically download to the card.
Thank you so much!
Thank you so much!
