I downloaded cosmos and I am currently using that for my battery usage. But the problem with my storage was not solved as it only clears junk only from internal memory.
Later I checked the SD card on my computer and I deleted few of the things which came installed like the manual:500MB .. and PC companion the lots of caches .. etc etc .. old pics which I have already deleted or moved to PC had thumbnails and so much other junk stuff ... now the status is 1.38GB free space .. I am happy now .. Thanks.
