Phone won't rotate to landscape
Make sure that, when you calibrate the G-Sensor, the phone is laying flat on a level surface (e.g. on a table, camera lens touching the table top).
G-Sensor calibration is Settings > Sound and Display > Bottom of the list
It may take a second or two for the display to swap between portrait and landscape at times.
Upvote 0
I feel kinda stupid for not finding this earlier, but here is the fix:
Settings -> Sound & Display -> Orientation (about halfway down)
Checked, it will auto-rotate to landscape.
Unchecked, it will stay in portrait.
I don't ever remember changing this setting, but there it is. Works fine now, and I like my Android again.
Upvote 0
BEST TECH IN 2023
Smartphones
