Pls help me I'm struggling mid x5a
Hi everyone,
I really help someone can help me I got a MID X5A from Amazon a week ago I have been using it daily as an ebook reader usually on Kindle yesterday while I was reading the battery died. I plugged it in and turned it on this morning and it has frozen completely on the android screen and there is nothing I can do to get it to change.
I have hunted the web all morning to try and get some answers but nothing. I'm getting very frustrated as the user manual says to contact customer service for help if you can't work it out but there is no number provided and I can't find anything anywhere!!!!!
I'm about to lose the plot so can one of you lovely people help me or do i just ring amazon where i ordered it from?
Thanks in advance
Hi everyone,
Thanks in advance
Upvote 0
Take off the battery and after a while to place the battery to the tablet again. Then check out the condition.
I believe this is a sealed battery "No user serviceable parts inside" device, like most tablets. Opening it up will void the warranty.
@cindernatalie if it won't reset by poking paper-clip or something into the reset hole, just call Amazon and RMA it. It's faulty, more than likely the software ROM has become corrupted or damaged due to poor quality. A very common problem with "MID" tablets.
Upvote 0
BEST TECH IN 2023
Smartphones
