Root Possible GPS fix
Zenwafer
With so many having troubles with GPS I felt obligated to share the post from over at the Prevail forum that helped me fix mine on that phone and this one
As I couldn't find it quick enough for my liking here's a quick rundown of what it said to do
You'll need Root access for this, hence my posting in the All Things Root section :p
From Google Play, grab the free apps FasterFix and GPS Fix
Turn on your GPS under Settings>Location services>Use GPS satellites :rolleyes:
Run FasterFix, following in app instructions to select your region's server
Then run GPS Fix, letting it take as long as it needs to find you. If the location is not quite right when it does find you, run it over and over again until it's as close as you can live with
And there you have it.
If this works for you let it be known by leaving a reply and hitting that thanks button :thumbup:
