I just moved to rural NM and have found that when my n4 connects at h & h+ my data never loads. At edge speeds it takes a very long time but actually loads.
Is there a way to always connect to edge? Or another fix for this?
Actually my APN was set to metropcs instead of T-Mobile. Got they switched. Hopefully it will help. There also was an option in the menu there for 2g or 3g as my preferred. Thank you for the help.
