Print directly from the phone
zoxxo
Jul 25, 2010
528
75
Issaquah, WA
I don't know if anyone noticed this, but the ICS upgrade brought an option that allows you to connect and print directly from your phone. I have two printers at home and was able to get my phone to connect and print to the newer wifi enabled inkjet. Sadly the older laser printer is not supported so I'm still surfing for a solution for that printer.
I honestly don't think I'll ever print from my phone, but it's nice to know that it's there if I need it...
Google itself also has offered the service for a while. You might find better compatibility.
Google - Cloud Print
https://play.google.com/store/apps/details?id=com.pauloslf.cloudprint
Upvote 0
BEST TECH IN 2023
Smartphones
