Problem with World Clock Times
oldbono
I noticed something very strange with the World Clock on my HTC Eris. The times for Montevideo, Uruguay and Buenos Aires are both incorrect. Referencing NY time, Montevideo should be 3 hrs later. It only shows it as 2 hrs later. Buenos Aires shows 3 hrs later than NY time. It should be 2 hrs later. So it appears that these two World Clock times are flip flopped. All other times; e.g. Rome, Tokyo are correct. Any ideas what could be causing this problem?
This may not be the correct answer to your question, but you never know...
I live in richmond california. My city isn't hard coded into the clock app so the app picks up richmond virginia...
I have to add the city next to mine.
Can't imagine they forgot to add Buenos Aries...
No actually Buenos Aires is in the Eris World Clock...just the incorrect time. It should be 2hrs later than NY, yet it shows as 3hrs. Could you try it referenced to your California time to see if you if you get the correct time? Thanks.
