darkcyber
Android Expert
I have rooted my Gear one and used Odin 3.09 and went through the process of uploading TWRP recovery onto it and it checks out fine. Then when I reboot and try to enter recovery...when I select recovery I get the little green android guy and it says it is installing additional files or updates. Then it boots up and it is wiped and I have to select restore and then select my note 3 again. Any suggestions?
