Problems since update
Anyone else having a lot of slowness and random resets since this most recent update? I did a FDR and I'm still seeing the same issues. I used to get the error where it says something isn't responding sporadically; however, now I'm seeing it probably 10 times a day (and I'm not a high data user trying to constantly stream video or anything). I am also getting a lot more random resets when everything just gets quiet before hearing "droooooiiid".
Anyone else had this and found a way to get it working properly?
Hello on a android device you can do more than one factory data reset . sometimes it maybe a data glitch from WiFi or carrier data when you got the zip downloaded if problems still exist may try to do the update manually from copying zip from a certified site and put on a SD card and flash from the device.
Welcome to Android Forums.
You could try running in Safe Mode (disabling all apps you added without uninstalling them). If the problems stop they are caused by an app that you added.
... Thom
