Root Problems W/ OC Kernel/Ext2 Rom
virusbetax
I have had many problems that bothered me very much. this has been one of the biggest. For some reason my keys on the behold 2 are acting up. I comfirmed this by using the internal built key test in the CwM Recovery. one button performs three different functions while others dont perform there function specified only the opposite. this is happening with the end key the cube button and the lock and camera button. i would like to know if ay of you guys have had the problem so i can make my decision on odining the original firmware and then moving back to the galaxy rom.
Thanks Guys for your help!
Could you help me? what should i do? i cant even use my phone without the buttons interupptions. and also what file or files do you want me to replace?Thanks for help!
i have already tryed to reinstall the ext2 zip but same results everytime. do you think its the kernel? or the buttons on the hardware? i might try going to stock and then back if that works. im really tired of all of the problems.
i turned on my phone today and it seemed like the buttons were back to normal. this happened once before but automatically fixed it self. i am positive that its either the kernel or the rom. but i will perform the factory reset since im tired of the problems. its not really worth enjoying if it happens every day to you.
EDIT: I just performed a key test and all the keys are functioning properly again...... weird......
what do you think caused it? i have never dropped or soaked the phone in water.......then waht coud it be?
