T
terrence1
Guest
Anyone looking to find Tips and Shortcuts for your Motorola Titanium?
All you need to do is access the Help Center located on your device. Just press the center icon located at the bottom of your touch screen to access the app's drawer / scroll down to find the icon label Help Center.
There you will find a Motorola Titanium user guide which gives you information on how to operate the Motorola Titanium mobile phone correctly, such as setting up service, setting up your phone, turning your phone on and off, making and answering calls, messaging settings, troubleshooting, web and data services, using a microSD card with your phone, microSD settings, turning Bluetooth power on and off, taking the pictures, playing music, maintaining safe use of and access to your phone, and many more.
The second TAB called TIPS provides you with additional information on customization and preference setup to allow easy access to your favorite and most used features.
Take a look for yourself and I hope this helps!
