Rapidly flashing dim red light?
Okay, so. On the Huawei Prism, the notification LED is located under the silver mesh earpiece. Can anyone tell me what the second light is? It's located on the side opposite the notification light between the T.Mobile logo and the earpiece. I'm just curious especially because I can't find it mentioned in the manual nor online. I've had the phone about three months and have noticed before, but it's ever been on this long.
Pardon if it's a dumb question. :o
Hi Raevyn and welcome to Android Forums!
Sorry for the LONG delay, this isn't a very highly populated forum, I'm afraid. Hence the lack of response.
I assume your battery is fully charged or not charging while this light is on?
Anyway, it's great to have you here :)
The second LED (colored red) that you are seeing, located to the right of the earpiece, will flash when you're on an active phone call or using the Visual Voicemail (VV) app.
It will flash, if the call or use of the app, is on the mobile network or WiFi.
I did not find this in the manual either.
Hey thanks! I gave up checking for a bit, but to answer your question, Chief, the light flashes regardless of the battery charge. Also, the light only comes on sometimes and will stay on for days at a time, then stop for a few weeks. I don't use the VV and it seems to do it regardless of whether or not I'm using the mobile network or wifi. It hasn't come on since I've posted this, are you positive that's what it indicates?
Yes. That red LED blinks rapidly when you're on a phone call (mobile network or WiFi).
