Koumajutsu
Android Expert
Koumajutsu here, This post is a copy of:
http://androidforums.com/galaxy-pre...lockworkmod-based-recovery-prevail2-ring.html
because it's quite possible it works just fine on the Ring as well.
We need brave souls with copies of their original recovery so they can roll back if it doesn't work to give this a try.
The following is a copy of the body of the referenced post.
Screenshot
I have the first build of CWM for our phone. It's nearly complete but quite usable. The only things missing are ADB and I cheated a little in supporting the internal sdcard which may lead to issues if an update.zip wipes /data.
(Turns out the internal SDcard is actually a folder in /data)
This works on the Prevail 2. It is untested on the Ring but should work.
I don't have a good screenshot as of this moment, nor a good copy of Odin to use bundled with it. Heimdall works great though
here it is: https://www.dropbox.com/s/d0b3hr8t14p2p1e/CWM_Prevail2_Ring_Koumajutsu.tar
Thanks go to Koush for supplying the source.
Shabbypenguin for helping me where I got stuck, supplying me with my initial device tree, and helping me deal with fstab issues.
And to OUDHitsquad for motivating and listening to me vent
Screenshot
