Hello,
i am searching for how to set the ringtone via the backend, i have a rooted shell.
Background: i installed a nightly cyanogenmod and it always has the call ringtone same as the notification tone. i hoped you could point me to the system setting within the backend so i can check where the cause of the error ist:
maybe something like parameter pref_key_ringtone within some file like /data/data/com.android.mms/shared_prefs/com.android.mms_preferences.xml , but thats for mms...
known places for older android versions are also welcome.
yes i tried using some file explorer or ringtone maker, they cant change it
thanks
thanks
