A while ago my dog got ahold of my Rogers DREAM phone. The phone is fine, except the casing is all chewed on and the power button seems permanently pressed in.
After searching on eBay, I ordered a replacement casing at a reasonable price. It arrived a short time ago and I just started the process of moving the hardware over.
Now, I'm sitting here with my HTC DREAM in pieces in front of me. The process of moving to a new case has been pretty straightforward, except for the user interface area. For some reason, I cannot get this assembly to clip to the main assembly. It seems that the UI assembly is too "thick" and won't allow the casings to clip.
Other that this issue, the TMobile casing seems to be a match for the Rogers Dream.
I've moved most of the hardware to the new casing, but I cannot get the user control module to clip to the main casing. I had no problem moving the user interface hardware to the new UI casing, but something within that setup leaves the electronics raised just a bit too far.
...so, are there any replacement casings for a Rogers DREAM phone available out there?
Any other options for a perfectly functional, but chewed on Dream?
