Root Roll Call - Ok guys, what you running on your mt?
rdoac
Saw this done on another phone..
This is a chance for the lurkers (and the regulars too) to write something. What ROM/ Mods / Restore utility are you guys running? I'll start:
CM7 Chairshots dev version with ICE10, clockwork 6 (although I have nand backups of U9000, Sharp, CM9 - which I would use but need the camera for check posting)..
Who's next?
I use mtdev cm9, amazing performance and stability, and they are so close to getting the camera :) might be within the week if were lucky
I am using mtdev cm9s latest with b randons cwm 6 with build.prop tweaks for battery and performance as well as init.d tweaks for battery and performance.over/underclocking with setcpu .under/over volting with incredicontrol. Getting better read/write speeds on SD card with SD booster. Running very smooth. Probably one of the top rooms on here even without camera!
MTDEV CM7, Chairshots 10/21 dev version with Ice 10 also. CWM 5.0.4 (will migrate to CWM 6 once AppExtractor v 2 is out of beta... Soon I hope)
Lightning Launcher w/Wave Launcher on top.
Using System Tuner Pro for all over/under clocking and governor, under volting, SD card cache/scheduler duties... Best app ever, btw.
Also using my invisible glowing lockscreen mod
With Govt Mule Dose logo for lockscreen marker and app drawer icon on home screen
Screenshots, was using Mixer theme at the time.
I'm just using the MTDEV cm9 10/28 edition. Although the phone does not currently have service on it. Yah, I decided to keep one of the 3 Triumphs I had in case the Republic wireless thing doesn't work out
MTDEV CM9, was running 7 until a few days ago but with the time change I figured I wouldn't be needing the camera as much. It's really smooth, and it looks like the camera is around the corner
MTDEV CM7 10/21 with ICE 10 and holo launcher.
I've got a new baby, so not having a camera isn't really an option.. Once it works, I'll give CM9 a shot.
I use Sharp ROM 2.2.2.....and FMR Memory Cleaner app to free up memory space giving me two days of battery life with this rom.
currently running MTDEV-CM9 build 20121028. also using CWM Recovery 6.0.1.5.
tried MTDEV-CM7 for a week. liked it but CM9 "ICS" is way cooler! :p
..was using Minimal Triumph ROM for the longest time.
mtdev cm9 10/28 as daily driver, holo launcher, cobalt theme, cpu min/max 122/1209 interactive (set in stock settings, default gov, not too sure which one to use), JuiceDefender Ultimate, Titanium Backup Pro, Rom Toolbox Pro, Dolphin, ES File Explorer, Player Pro, Quicker, Avast!, Skype & Camera will work again later..
