i had to switch off this rom cause i updated to the latest update and was having sound issues while in the phone call. had to put it on speker then off to hear anything the person on the other end was saying. dont know if thats a know issue but i dont have the problem on stock or superr rom.
I'm running stock and I have that same problem..
Idk a friend of the wife said a place close by fixes or replaces screen for $50 does it sound reasonable?
Well I've noticed the battery life not to be good after and before i added the kobalt theme to warpedkitty and i looked at the battery and noticed android system takes up 40 to 50% of battery which is not right so what i did was charged my phone to 100% left it connected applied a stock lwp instead of a normal image and rebooted afterwards my android system ran in the 20s% which made my battery last longer: D
How did you get it down to just 5% ??20% still seems high. just checked mine and it is at 5%
Not sure but I don't use Warped Kitty...certainly NOT saying that is why my Android is at 5%, just saying it's not comparable. One thing is that I am running Greenify. Maybe it makes a huge difference?How did you get it down to just 5% ??
i will try that and see what happensRe-calibrate your battery.
another thing that happens to me and i dont know if there's something wrong with my sdcard or if its the rom but i can only download pictures from chrome if i try to save pictures that i get through mms it says that thew image was saved but does not show the download sign on the status bar and the same thing through facebook messenger i have to go to the browser to be able to save the pictures. any idea what might be wrong??
