Okay ive edited this ROM so GSM users can use it! You can now use your data service, just that you need to set your APN network but its easy! I didnt make this ROM, this ROM was made by fuzhan8 or jssa28 not sure! But thanks any way! It has the same bugs as in the original CM10.1 (Link) but this one has a little bit of different mods! Ive added:
-Beats Audio and Google Edition boot animation
-Modded built.prop
-Mobile Network Configuration Menu
-Better GSM Signal
and I dont remember what else I did, but did other things too! lol I recommend you guys using the gapps ive provided, because it has YouTube app working! Just dont update! Leave it how it is and it will work perfectly!
Just flash gapps! Heres a link of reduced gapps, so it wont be so heavy! (Link)
Download ROM: Link
WARNING!: After installing ROM and configure the start up go to System Settings>Performance>Processor and edit MAX to 1497 or lower! When finished check the box on the bottom where it says Set on boot! And finished!
-Modded built.prop
-Better GSM Signal
Download ROM: Link
