willzthabeast
Tried it also. I am unable install every app. It just reboots after downloading the app and trying install.
Other than that it is working great
ya i did the same but it jus kept rebooting
Are you a ZVC root willzthabeast?
omg i just went through all the trouble of downgrade last Saturday and now you guys come out with root and roms for zvc. gaaaaah
adb reboot recoverySo. I have tried injecting apps from pc to the phone. The phone just reboots everytime an install goes on.
My problem is that I dosa not know how I am going boot into recovery mode, because I don't have the app and its impossible for me to install it and when I press the power button I do not see that option, anyway I can boot into recovery mode a different way?![]()
Thank you! Saved meadb reboot recovery
was this with GSE-C or stock?? If it was wit hGSE-C it clearly states to do a full wipe b4 installing.Found a fix for the no install apps problem. Boot into recovery and wipe data. That's a factory reset for the rom. Once you boot again you should be able to install apps. Hopes that helps some people..cause now I can install apps.
most welcome, the reboot option in the AIO does the same cmdThank you! Saved me
you can get rom manager for free![]()
https://market.android.com/details?...xLDEsImNvbS5rb3VzaGlrZHV0dGEucm9tbWFuYWdlciJdH
Here I fond the tomorrow manager....so now I get on the com and install this the same way I did my root? And how do I do the total wipe like u where talking about? THANK YOU PG FOR THE HELP thus far.....
dl the rom n copy to your sdcardLol I told u I have the rom manager... I found it.... but how do I wipe my system? And how do u install the new rom, the same way as I did my root?
I tried that with stock ZVC after upgrading trying to dup the issue n wiping didnt help then, so glad it worked for you. This has been a headache for me and have experience with all sorts of issues lol. I can just image whats its like for the 'just wants it to work' types lol.
Thank You for your hard work.
just got a question, Is the a way to get the stock battery meter and signal strength bar?
Everything else is working perfect.
Thanks.
