azoller1
Android Expert
DISCLAIMER: I AM NOT RESPONSIBLE IF YOU SCREW YOUR PHONE UP BY BRICKING IT!!! JUST FOLLOW THE DIRECTIONS
This rom is meant for smoothness, speed, stability, and battery life, and also customization.
Change Log 2nd post
Features
-Deodexed
-Zipaligned
-Heavily Debloated
-Superuser Rooted
-Xposed Frameworks And Modules
-Xposed Theme Engine App/Module
-LMT Launcher (Pie)
-Nexus 4 Bootanimation
-Google Now
-Android 4.2 keyboard
-LG Home3 UI
-Stock ICS AOSP Browser
-Sony Bravia Engine 2.0
-Regular Play Store App without keep shopping window
-Inverted Talk
-More Inverted Apps
-Custom Build.prop Tweaks For Battery Saving
-Other Speed Tweaks
-Very Good Battery Life
-Very Smooth Experience
-Ortriggers Awesome Kernel Included (OC upto 1.8GHz)
-CRT Off animation
DOWNLOADS
SCREENSHOTS
https://www.box.com/s/mmsevga9796y6vq236wy
https://www.box.com/s/05rysra6r8vf23s5phaf
https://www.box.com/s/thfbs38tx15jugs7fbit
https://www.box.com/s/io1w94cfri6kyto3y2vw
https://www.box.com/s/higdnw10jh43gb2sn1lz
https://www.box.com/s/yxftbqm46mybd8ra9e92
https://www.box.com/s/a58po9pv1uhdkfh372go
Installation
1.Download ZIP and extras
2.boot to cwm
3.WIPE DATA!!!! if coming from anything but this rom!
4.go to where the zip file is
5.install it and wait
5b. can fix permissions (not really needed now)
6. Reboot up, let it sit for a few minutes to let the tweaks start up
7. Then you can reboot again to finalize everything if you want to
DONATION LINK IN MY SIGNATURE!!
Change Log 2nd post
Features
-Deodexed
-Zipaligned
-Heavily Debloated
-Superuser Rooted
-LMT Launcher (Pie)
-Google Now
-LG Home3 UI
-Inverted Talk
-More Inverted Apps
-Other Speed Tweaks
-CRT Off animation
DOWNLOADS
SCREENSHOTS
How To Use Xposed Settings App
1. Open The Xposed Installer
2. Press Install/Update
3. Then click SOFT REBOOT once its done
4. Let it boot up then go back to xposed installer
5. Then click the modules tab
6. Checkmark the xposed app settings
7. SOFT REBOOT again
8. Open Xposed app settings app
9. Choose what app you want to mod
10. Once Clicked, press the off switch to make it turn on
11. change DPI to 160-177 for TabUI
12. Leave font scale, can change if you want to though
13. Set Screen (dp,px) to 800x1280
14. Can set other options to your preference
15. Set orientation to what you want
16. Press Save button
17. Then mod any other apps you want to
18. Then go back to xposed installer
19. And then SOFT REBOOT one last time
20. And make sure you soft reboot instead of regular reboot
21. Lots of steps but its very easy! And worth it!
22. Enjoy you tablified LG Spectrum
Installation
2.boot to cwm
