Root [ROM] Minimal Triumph v1.0.9 and v1.1 (Final Release)
how do I change the stock power up and shut down animations? nice rom btw
Edit: I also can not restore backup to launcher because the files don't exist
can you please upload them?
Sorry it took so long guys but its here look in the OP for the download link and new features :)
Do Not Flash bKernel v1.01 ive been doing some testing and found that v1.01 and Minimal Triumph don't play nice so v1.0.8 is still using DEV 0.24 ext3 version of bKernel
also for full effect of update backup your apps with Titanium Backup, Wipe Data/Factory reset, Then flash Minimal Triumph v1.0.8
i know you guys will love it :)
Changelog for v1.0.8
v1.0.8-
  • Removed Es File Explorer replaced with themed File Manager
  • ICS Smileys added for SMS/MMS
  • Changed LCD Density to 215
  • Mobster Tweaks v2 - Higher Performance/Better Visual Performance/Battery Saver
  • Updated apps
  • Minimal Triumph Bootanimation by CornfedChris
  • Blacked Out Faster Shutdown
  • Changed Default Wallpaper and Tweaked theme
Credit goes to CornfedChris for the boot animation
wow hes good :) i modded the dock abit. ill post screenie up later. great rom. running smoothly like always :)
idk y the image comes up red wen i used the app...its not suppose to b red its black n white only including background wallpaper n dock n apps.... >.<
just flashed n saw boot anmation...oh..my..gosh...amazing....keep up the great work mobsters! i luv minimal :)
Thanks, and nice work Mobster!
Sorry I took a couple months off on ya guys. I had a friend move into my computer room so I had to unhook everything and store the desktop away for awhile and its been sitting in the basement getting lonely. I'm in the process of getting it hooked up to my 42" hdtv in my room tho! ;) Then I can continue my work.
I've been checking out the new roms and kernels and everything looks awesome! Can't wait to see what gannon5197s got up his sleeve. Keep it up!
Thanks, I appreciate it!
I've been checking out the new roms and kernels and everything looks awesome! Can't wait to see what gannon5197's got up his sleeve. Keep it up!
great job on the boot animation. its amazing :D
somehow i cant install/find it on play store...i tried through website...it says device not compatible....
Yeah that's because of the new LCD density if you change it to 240 (found in the build.prop under mobster tweaks) and reboot it'll go back to normal
i was just wonder if you could tell me how to edit something so i can have a signature on texting option, please :3:) because i want to stay on stock not use other options like TextFree and such
The Stock Messaging app does not have an option for Signature Maybe CM7 or after market messaging apps have that option
yes ik, i have a flashable zip that puts a sig option on CM7 i was just wondering if there is a way to edit the stock one to put a sig option in it
ok thanks :) keep up the good work! n wats the diff between 215 dpi n 240?
215dpi looks crisper and zoomed out - to me looks more HD
240dpi is the stock LCD density and is more compatible with apps in the Play store - i go back if i need to install something from Google Play
Mobster, thanks for the update it looks great.
I have switched back to 240dpi but I still can not download pretty much any of my purchased apps, beautiful widgets, upward mobility comp tia A+ study app, Paper camera, pandora, facebook. All still will not download for me plus some others I am sure.
edit 1:Also I tried wiping my cache and dalvik cache again incase the market wasa just saving something about the compatability list, this did nothing.
edit 2: I changed build.prop back to wx435 and motorola instead of the thunderbolt information and again cleared play store cache and rebooted. Now i can install everything, except the 3d games from gameloft, but most of them check the device in game now anyway and would not work even when i could install them from the market.
okay this will be fixed in the next update :)
