Root [ROM][Nov 7][G900FXXU1ANJ1][4.4.2][Knox 0x0][ART][Private] NeatROM v2.5.3
_Sale_
Jun 10, 2012
660
1,262
Serbia
www.neatrom.com
Welcome to NeatROM for S5 G900F
Simple, clean and reliable
Please read the Terms of Use carefully:​
Please note that you will get Knox 0x1 (warranty void) when you flash: either a custom kernel or custom recovery.
To check your Knox counter status, boot into Download Mode (power off the device and then press Volume Down + Home + Power, then press volume up if the triangle screen appears) and the Knox flag is shown in the list at the top left hand side of the screen.
If, "KNOX WARRANTY VOID:", is showing as 0x0 then you have not tripped the Knox flag.
If it is showing as 0x1, your Knox flag is permanently blown and your phone is no longer suitable for Knox security purposes.
By installing this ROM, you take full responsibility of it's use. I am not responsible for anything that may happen or does happen to your phone, including KNOX, as a result of installing this Rom. You are choosing to install this yourself and thus accept any/all risks involved.
  • NeatROM for Samsung Galaxy S5 G900F
  • November 7, 2014
  • Firmware: G900FXXU1ANJ1 NeatROM v2.5.3 (4.4.2)
  • Build date: Wed Oct 1 23:12:44 KST 2014
  • Kernel: XXU1ANJ1
  • Modem: XXU1ANJ1
  • CSC: AXX1ANG7-Multi (ALB, ATO, AUT, BGL, BTU, CAC, CEL, CMF, CPW, CRC, CYO, DBT, DTM, ETL, EUR, EVR, GLB, HTS, ILO, ITV, KOR, LUX, MEO, MET, MIR, MM1, MOT, MSR, NEE, NZC, ORX, PCL, PHE, PHN, PRO, PTR, ROM, RWC, SEB, SEE, SER, SFR, SIN, SIO, SKZ, SMA, STH, TEB, TEM, TEN, TGY, THL, TNZ, TOP, TPH, TSI, TSR, TUR, TWO, VAU, VDI, VDS, VIM, XEC, XEF, XEH, XEO, XME, XSP, XTC, XTE)
  • Change List: 2089850
  • Available languages in ROM: Azerbaycanca, Bahasa, Catala, Cestina, Dansk, Deutsch, Eesti, English, Espanol, Euskara, Filipino, Francais, Gaeilge, Galego, Hrvatski, Islenska, Italiano, Latviesu, Lietuviu, Makedonski, Magyar, Nederlands, Norsk bokmal, Ozbekcha, Polski, Portugues, Romana, Shqip, Slovencina, Slovenscina, Srpski, Suomi, Svenska, Tieng Viet, Turkce, Udru, Uzbek, Greek, Bulgarian, Russian, Ukrainian, Korean, Chinese...
  • Default Language - English
  • Aroma installer
  • Option to Full Wipe from Aroma
  • Odexed
  • Rooted
  • BusyBox
  • SuperSU v2.14
  • Private Mode
  • ART Compatible
  • NO WIPE
  • Enabled All Languages for Samsung Keyboard
  • Enabled Secondary Symbols on Stock Keyboard
  • No Auto Converting messages to MMS
  • Modded Mms (Sent Time instead of Received Time)
  • Enabled Sending/Receiving MMS without Data
  • Enabled Signature in Messaging
  • Enabled Scheduled Messaging
  • Enabled Split Mode in Messaging
  • Enabled Save VMessage
  • Enabled VCalendar
  • Enabled VTask
  • Enabled Save/Restore Messages
  • Enabled Call back Button in Messaging
  • Enabled Folder View in Messaging
  • Enabled Delete Button On ActionBar in Messaging
  • Enabled Option Delay Send SMS
  • Enabled Screen On-Off Option in Messaging
  • Enabled Vibration Option in Messaging
  • Enabled Group Message Option in Messaging
  • Increased SMS Hour Limit to 1000
  • Unlimited Recipient SMS/MMS Limit
  • Unlimited Contacts to SMS,MMS
  • No SMS or MMS in Call Log
  • Enabled Message Block Options
  • Enabled Call Block Options
  • Enabled Call Button in Logs
  • Enabled More Contacts (999)
  • Call Recording
  • Enabled Call & MSG Blocking
  • Enabled Camera Sound Menu
  • Enabled Camera During Call
  • Enabled Screen Capture Sound in Camera
  • Modded Camera (Removed Camera Battery Warnings)
  • Added Trim option in Gallery
  • Added Flash Player
  • Added Quad Multi Window
  • Added Exit Browser Option
  • 4 Way Reboot Menu
  • Disabled scrolling cache
  • Enabled Hidden Torch Settings
  • NeatROM WallPapers
  • Allowed Installation Of Apps From Unknown Sources By Default
  • Disabled Verify Apps By Default
  • Disabled Safe Volume Warning
  • Disabled Battery Cover & Charging Cover Toasts
  • Enabled Menu Alarm Alert During Silent Mode
  • Default Screen Animation speed set to 0.5
  • Cooked using JustArchi's awesome kitchen Thanks to [MENTION=5161352]JustArchi[/MENTION]
  • NeatROM | Simple, Clean & Reliable set as default home page for Browser
  • Removed Knox
  • Read/Write to External SD Card enabled
  • Rebuilt all permissions
  • Init.d Support
  • Init.d Tweaks
  • Build.prop Tweaks
  • Multiple other Tweaks
  • Added NeatROM Control in System Settings
  • Added Network restriction quicksetting toggle
  • Added S Beam quicksetting toggle
  • Added Smart Scroll quicksetting toggle
  • Added Reading Mode quicksetting toggle
  • Added Air View quicksetting toggle
  • Added Air Gesture quicksetting toggle
  • Added Quick Connect quicksetting toggle
  • Added S Finder quicksetting toggle
  • Added Permissions Manager in System Settings
  • Added S-Finder/Quick Connect toggle
  • Added Power button on StatusBar toggle
  • Added Wallpaper Scrolling toggle
  • Added Battery Bar Toggle
  • Added Battery Bar Color Picker
  • Added Battery Bar Style
  • Added Battery Bar Thickness
  • Added Battery Bar Animation
  • Added ScreenRotation toggle in Accessibility Settings
  • Added Accessibility in Power Menu toggle
  • Added Smart Screen Options in Settings/Display
  • Added Terminal app toggle in Developer Options
  • Enabled Developer options as default
  • Enabled Flashlight widget
  • Enabled Mono/Stereo Audio widget
  • Enabled Mobile Hotspot widget
  • Enabled Negative Colors widget
  • Added 3minit Battery Mod in Aroma (over 1,070 battery types) Thanks to [MENTION=4619873]gharrington[/MENTION] - (original thread)
  • Added CSC codes: BHT (Bosnia and Herzegovina), ATT (USA), CRO (Croatia), VDH (Hungary), XSG (UAE)
  • Enabled TWlauncher themes (9 in aroma)
  • Added Animation scales 0.25 and 0.75
  • Added 650 fonts in Settings/Display Thanks to @Winb33
  • Added Hardware Version in Settings/About Device
  • Increased ToolBox apps from 5 to 8
  • Increased Quick Settings apps from 12 to 20
  • Fixed Notification Toggles
  • Fixed Quick Glance
  • Added Phone INFO
  • Updated SuperSU
  • Other minor changes and fixes
  • Data Icons:
    - International
    - T-Mobile
    - AT&T
    - Sprint
  • Option to Install:
    - Stock Bootanimation
    - NeatROM Bootanimation Thanks to [MENTION=2915835]momo.martinovic[/MENTION]
    - Google Bootanimation
    - Android L Bootanimation
  • Boot Sound:
    - Enable
    - Disable
  • Apps:
    - FlashPlayer
    - DropBox
  • Choose the Apps you want to Install:
    - Google Books
    - Google Chrome
    - Google Play Movies
    - Google Drive
    - Google Magazines
    - Google Maps
    - Google Music
    - Google Play Games
    - Google+
    - YouTube
    - ChatON
    - Email/Exchange
    - Flipboard
    - Help Hub
    - Live Wallpapers
    - Memo
    - Mobile Print
    - Polaris Viewer
    - Samsung Update
    - Samsung Fonts
    - Calculator
    - Music Player
    - Video Player
    - Widget Active Application
    - TalkBack
    and many more...
    I probably forgot something
Big Thanks to @Twinn
November 7, 2014
MD5 Sum: 9c00b9d735606962ea391e6183a2ecc6
Please don't post any mirrors. I count the downloads
Ask me first for permission if you want to use my work in your ROM
Complete NeatROM File Mirror is available here Thanks to [MENTION=4478812]ApriliaM3[/MENTION]
Installation Instructions via CWM recovery (KNOX 0x1)
1. PLEASE make a Nandroid backup of your current ROM!!!!
2. Backup your Internal SD to your PC
3. Download NeatROM onto your phone (either internal or external SD card) and reboot your phone into recovery mode (turn your phone off and then press & hold Volume Up & Home & Power buttons)
4. Reboot your phone into recovery mode (turn your phone off and then press & hold Volume Up & Home & Power buttons)
" IF YOU'RE COMING FROM ANOTHER CUSTOM ROM OR HAVING ISSUES WITH APPS FORCE CLOSING AFTER THE FIRST BOOT, IT IS HIGHLY RECOMMENDED TO WIPE DATA AND THEN INSTALL NeatROM"
5. Select "Install Zip" and then navigate to where the NeatROM zip is located on your SD card
6. Once the Aroma Installer starts, select the options that you would like to install
7. When the ROM has finished installing, and at the end of the installation process in Aroma, UN-TICK "Reboot Device"---pic1
8. Remove the battery for a few moments and then put it back in, boot into Download Mode (press Volume Down + Home + Power, then press volume up)
9. Download and open PC Odin
10. Download, extract and flash MODEM (load as CP) and BOOTLOADER (load as BL) in ONE STEP---pic1---pic2
11. If something goes wrong and your device will not boot after flashing, try to remove the battery for a few moments and then put it back in, press and hold VolumeUP + Home + Power to boot the device into recovery mode and do a "wipe Data"
12. Enjoy your NeatROM
Installation Instructions: If you're coming from NEATROM (KNOX 0x0)
1. Backup your Internal SD to your PC
2. Backup your Apps
4. Check the md5sum of the NeatROM.zip
5. Run Mobile Odin Pro---pic1---pic2
6. Load the NeatROM.zip file with "OTA / Update ZIP"---pic1,---pic2
7. UN-TICK "Enable EverRoot" (NeatROM is already rooted)---pic1
8. UN-TICK "Wipe data and cache"---pic1
9. UN-TICK "Wipe Dalvik cache"---pic1
10. Select "After flash..." then select "Download mode"---pic1,---pic2
11. Select "Flash firmware"---pic1
12. Once the Aroma Installer starts, select the options that you would like to install
13. When the ROM has finished installing, and at the end of the installation process in Aroma, UN-TICK "Reboot Device"---pic1
14. When the phone goes into Download Mode, download and open PC Odin
15. Extract and flash MODEM (load as CP) and BOOTLOADER (load as BL) in ONE STEP---pic1---pic2
16. If something goes wrong and your device will not boot after flashing, try to remove the battery for a few moments and then put it back in, press and hold VolumeUP + Home + Power to boot the device into recovery mode and do a "wipe data/factory reset" then "reboot system now"
17. Go to Settings/Security/ and UN-TICK "Reactivation lock"
18. Go to Settings/Security/Security policy updates/ and UN-TICK "Automatic updates"
19. Go to Settings/Security/ and UN-TICK "Send security reports"
20. Enjoy your NeatROM with KNOX 0x0
Installation Instructions: If you're coming from a Samsung stock NON-Rooted ROM before NG2/NG7/NG9/NH4/NH6/NJ1 (KNOX 0x0)
2. Go to Settings/Security/ and UN-TICK "Reactivation lock"
3. Go to Settings/Security/Security policy updates/ and UN-TICK "Automatic updates"
4. Go to Settings/Security/ and UN-TICK "Send security reports"
5. Go to Settings/About device/Software update/ and UN-TICK "Auto update"
6. Root your phone with Towelroot---pic1---pic2
7. Reboot and install SuperSu from the PlayStore
8. Run SuperSU and select "Continue", "Normal" and "OK". ---pic1,---pic2,---pic3 Wait a few seconds and then reboot device
9. Run SuperSU again and select "Try to disable KNOX"---pic1,---pic2
10. Reboot and download NeatROM onto your phone
11. Check the md5sum of the NeatROM.zip
12. Purchase and install Mobile Odin Pro
13. Run Mobile Odin Pro---pic1---pic2
14. Load the NeatROM.zip file with "OTA / Update ZIP"---pic1,---pic2
15. UN-TICK "Enable EverRoot" (NeatROM is already rooted)---pic1
16. UN-TICK "Wipe data and cache"---pic1
17. UN-TICK "Wipe Dalvik cache"---pic1
18. Select "After flash..." then select "Download mode"---pic1,---pic2
19. Select "Flash firmware"---pic1
20. Once the Aroma Installer starts, select the options that you would like to install
21. When the ROM has finished installing, and at the end of the installation process in Aroma, UN-TICK "Reboot Device"---pic1
22. When the phone goes into Download Mode, download and open PC Odin
23. Extract and flash MODEM (load as CP) and BOOTLOADER (load as BL) in ONE STEP---pic1---pic2
24. If something goes wrong and your device will not boot after flashing, try to remove the battery for a few moments and then put it back in, press and hold VolumeUP + Home + Power to boot the device into recovery mode and do a "wipe Data/factory reset" then "reboot system now"
25. Go to Settings/Security/ and UN-TICK "Reactivation lock"
26. Go to Settings/Security/Security policy updates/ and UN-TICK "Automatic updates"
27. Go to Settings/Security/ and UN-TICK "Send security reports"
28. Enjoy your NeatROM with KNOX 0x0
Installation Instructions: If you're coming from a Samsung stock NON-Rooted NG2/NG7/NG9/NH4/NH6/NJ1 ROM (KNOX 0x0)
2. Download, extract, boot the phone into Download Mode and flash this ROM using PC Odin (use AP on Odin)---pic1,---pic2
3. Boot the phone normally. If something goes wrong and your device will not boot after flashing, try to remove the battery for a few moments and then put it back in, press and hold VolumeUP + Home + Power to boot the device into recovery mode and do a "wipe data/factory reset" then "reboot system now"
4. Go to Settings/Security/ and UN-TICK "Reactivation lock"
5. Go to Settings/Security/Security policy updates/ and UN-TICK "Automatic updates"
6. Go to Settings/Security/ and UN-TICK "Send security reports"
7. Go to Settings/About device/Software update/ and UN-TICK "Auto update"
8. Root your phone with Towelroot---pic1---pic2
9. Reboot and install SuperSu from the PlayStore
10. Run SuperSU and select "Continue", "Normal" and "OK". ---pic1,---pic2,---pic3 Wait a few seconds and then reboot device
11. Run SuperSU again and select "Try to disable KNOX"---pic1,---pic2
12. Reboot and download NeatROM onto your phone
13. Check the md5sum of the NeatROM.zip
14. Purchase and install Mobile Odin Pro
15. Run Mobile Odin Pro---pic1---pic2
16. Load the NeatROM.zip file with "OTA / Update ZIP"---pic1,---pic2
17. UN-TICK "Enable EverRoot" (NeatROM is already rooted)---pic1
18. UN-TICK "Wipe data and cache"---pic1
19. UN-TICK "Wipe Dalvik cache"---pic1
20. Select "After flash..." then select "Download mode"---pic1,---pic2
21. Select "Flash firmware"---pic1
22. Once the Aroma Installer starts, select the options that you would like to install
23. When the ROM has finished installing, and at the end of the installation process in Aroma, UN-TICK "Reboot Device"---pic1
24. When the phone goes into Download Mode, download and open PC Odin
25. Extract and flash MODEM (load as CP) and BOOTLOADER (load as BL) in ONE STEP---pic1---pic2
26. If something goes wrong and your device will not boot after flashing, try to remove the battery for a few moments and then put it back in, press and hold VolumeUP + Home + Power to boot the device into recovery mode and do a "wipe data/factory reset" then "reboot system now"
27. Go to Settings/Security/ and UN-TICK "Reactivation lock"
28. Go to Settings/Security/Security policy updates/ and UN-TICK "Automatic updates"
29. Go to Settings/Security/ and UN-TICK "Send security reports"
30. Enjoy your NeatROM with KNOX 0x0
Installation Instructions: If you're coming from a Samsung stock Rooted NG2/NG7/NG9/NH4/NH6/NJ1 ROM (KNOX 0x0)
2. Backup your Apps
5. Purchase, install and Run Mobile Odin Pro---pic1---pic2
12. Once the Aroma Installer starts, select WIPE DATA and the options that you would like to install
My KNOX flag is still 0x0 :) but I am not responsible for anything that may happen to your phone including KNOX as a result of this guide
_alexndr
momo.martinovic
Twinn
daveyannihilation
ApriliaM3
tdunham
geohot
Chainfire
amarullz
Beta testers: @Twinn, @master_droid
If you want to send me a donation to show your appreciation for my work, I'd really appreciate it!
Big THANKS to ALL DONORS! Much appreciated!
Welcome to the Galaxy S5, All Things Root, forum Sasa! :)
For those of you who have never heard of NEAT ROMs or their developer, salesale, he and his ROMs are already a legend on both the Galaxy S2 and S3 forums. The builds are stable, lean, mean and keen and his support for them is second to none.
If anyone is looking for a de-bloated ROM then I urge you to try NEAT ROM. :thumbup:
Upvote 0
Hey Sale ;)
Nice to see you in the S5 section m8. Look forward to lots of NeatROM goodness for my phone :D
thanks guys :)
Have you got a good one for tab 2 10.1???
no mate sorry
Anything for S5 G900A?
soon ;)
Upvote 0
Hi Sasa!
I seem to be having a problem getting this ROM to use ART instead of Dalvik. I could not get Titanium Backup to freeze apps on ART on the stock, rooted, ROM and so I flashed yours and used TB to freeze some apps and then tried to switch to ART... but no go. Is this a restriction of the S5 firmware do you think?
(Alternative answer... It's me being thick! :stupid: )
Upvote 0
Hey buddy art doesn't work well on deodexed roms. My next Rom will be odexed so please be patient. Glad to see you here :)
Hi Sasa! Good to see you developing in the S5 world!
Unfortunately I'm still with S4, but a certain person we know only too well lost his S4 frollicking in a haystack, and has since upgraded to an S5.
Now I wonder who that may be.............?
Hi Sasa!
You're absolutely right butty.
Its you being thick!
:fight:
Upvote 0
A haystack I could have handled... this was a ruddy great field of the stuff! :girlhit:
:fight:
OK... so I got carried away in my excitement and forgot that Sasa's ROM was deodexed and therefore not compatible with ART. :stupid:
Upvote 0
Cheers Sasa!
Am running NG7, odexed, on ART, as opposed to Dalvik, with no problems whatsoever. :thumb:
I have installed the ktoonsez TouchWiz kernel as this offers me a myriad of options via the KTweaker app.
I'm pleased to say that you have not disappointed me with your Galaxy S5 ROM in the least.
Keep up the good work my friend and here's some more beers to help you along the way, (Confirmation number: 6X5386539F6328419). :beer:
P.S. Is there any way that I can get a white background, (inverted), Contacts list, similar to the S4 SlimKat version?
Upvote 0
Welcome sale good to see you here. I need some help i have installed the latest rom but my shealth app is not working keep getting Healthservive force close. I tried clearing the data in tb and it worked for a bit but stayed up again also private mode is not working keep getting private mode not enabled any ideas. Also has any change been Made to the stock samsung keyboard its changed and I can't figure out how to go back. The keys now have special character shortcuts above them and the continous input is broken it does not let me change my last entered word and the spacing is wierd.
Upvote 0
ok i have tried flashing the firmware back a couple of times more and did a full wipe but having the same issue with health services and private mode. Do i need to select certain things in aroma to get both to work together?
I already replied to you mate by email. Select securestorage false and clear data of shealth and healthservice
Upvote 0
BEST TECH IN 2023
Smartphones
