D
Deleted User
Guest
Welcome to:
GamerROM Orion
For the Nexus 6 (shamu)
The worlds Top #1 OS for the best gaming OS on the go.
Trailer:
COMING SOON!
GamerROM has arrived to the Nexus 6 since its public release for Samsung Devices, you came here because you want to dominate with the gaming os that wont let you down.
GamerROM Orion is the 12th Version of the GamerROM franchise and we want to share a few things with you before you install!
Let's Get Started!
Features:
- OTA Updates (Over-The-Air) Supported get updates easily without a breeze and view the thread with no issues
- Fast & Secured OS to keep your personal data from thiefs.
- Play Games at the highest framerate possible.
- High Quality Surround Sound (experience the best audio quality you never heard before).
- Pre-Installed Root Access (We install root immediately once you flash our OS)
- Awesome RAM Management (OS uses less ram to give you more to play those awesome intensive apps and games).
- Cast Your Games any chromecast up to 1080p Resolution at 60fps.
- Task Manager allows to keep your phone clean from apps using your ram powered by: ZTE
- Unique Features that you never seen before in GamerROM 11 on the S4!
Information:
NOTICE: G-Apps do not install automatically with this version of GamerROM, you will need to download & flash your own gapps from http://opengapps.org/ and flash it after you flash the OS......Keep also in mind you will need TWRP v3.2.0.3 or higher to install this OS otherwise you will get an error upon installation!
IMPORTANT: You can now install any kind of gapps as this build no longer contains any apps related to gapps except for Google's Android System Webview, so please DISREGARD MESSAGES IN THE FLASHER about flashing the modified pico or micro gapps!
NOTICE ABOUT THE Anti-Virus: The new built in anti virus application will ask for root, it's okay to allow or deny it, you wont be herrassed by having root access, but however my suggestion is to hide it in the application itself to prevent constant notifications, this app is 100% free with no ads and is updatable via the Play Store for FREE as well!
OTA (Over-The-Air) Updates Support Notice: you may have notice we do support OTA Updates, this means before the thread is updated with the new OS Version after the update has pushed to the cloud to everyones devices, once the update has been pushed out using Over-The-Air Updates, the thread will be updated once the update is pushed via MEGA and we need to inform that depending how many people download the update via OTA at the sametime will determin the speed of the download.
Warning: If you install the OS on low battery or below 50% we highly recommend to have your battery at least above 60% and you are fully responsible if anything goes wrong or off the rails, even though this may not happen, things can go bad really fast!!!..
Download OS Via App: https://play.google.com/store/apps/details?id=com.gamerrom.downloader
OS Official Release Date: 04/04/2019
Latest Update: v8.2
Build Status: Stable
Update Status: In Development for now
Latest Security Patch: October 5, 2019
Version v8.2:
• Applied updates from lineageos src.
• Applied security patch "October 5, 2019" update.
• Replaced GR Settings (L Speed) with GR Settings (SmartPack).
• Updated Magisk (root no longer is patched in kernel).
• Added Task Manager v3.0.
• LineageOS Stock Wallpaper added as default.
• Huge amount of bug fixes.
• Improved performance & stablity.
• Removed Google PDF Viewer & Archive Viewer.
• Added GL Tools (you can now echance your gaming experience).
Version v8.1:
• Updated Android System Webview.
• New Wallpaper design.
• Improved Dalvik VM.
• Improved Memory Usage.
• New Official LineageOS 15.1 Jelly Browser.
• Removed FM Radio due to it soon to require you to sign into google.
Version v8.0:
• Applied security patch "July 5, 2019, update.
• Updated FM Radio to v1.3.6 (this adds new stations and bug fixes).
• Improved some features.
Version v7.4:
• New Wallper design.
• New google bootanimation.
• Added Smart Manager to manage your ram use and kill apps automatically whenever their not in use to save up ram!
• Updated Google Opinion Rewards.
• Removed Google VR Services.
• Added new assets to @android/framework-res/assets.
Version v7.3:
• Applied June 5, 2019 Sercurity Patch.
• Fixed an issue with AudioFX not properly syncing with music.
Version: v7.2:
• Fixed a issue that still had the HTC Sense Launcher but no HTC apps installed and it has been removed snd replaced.
• Updated FM Radio to v1.3.5.
• Improved Dalvik/ART VM.
• Added a new Task Manager to view and manage apps to free ram and view resources!
Notice: We have fixed the update sever so you can update via the OTA Updates Application now!
Version v7.1:
• Updated Browser to a fixed version of the Jelly Browser.
• Updated Android System Webview to v75 Stable
• Made some impovements to dexoat
• Removed all apps partaining to HTC to save up RAM and to match GRO Pro's design!
Version v7.0:
• Fixed no SIM card bug.
• Reverted Webview back to v74 due to v75 being buggy and not loading websites correctly.
• This is the last and final update.
Version v6.0:
• Updated Sense Home from v9 to v10.
• Added HTC Location Services for HTC based apps only.
• Updated HTC Account
• Updated Android System Webview from v74 to v75.
• Added Achive Viewer (similar to what HTML Viewer does).
• Improved all features.
• Fixed an issue with camera not showing up in the launcher.
• Made adjustments to LTE configuration.
Version v5.4:
• Replaced Browser with Samsung Internet Browser Lite.
• Improved bluetooth and other features.
Version v5.3:
• Added Google VR Services
• Overhauled OS Design
• Improved RAM Swap
Version v5.2:
• Improved Application Memory Optimizations
• Improved Performance & Stability
Version v5.1:
• Applied security patch update to May 5, 2019.
• Added updates from lineageos src.
• Improved OpenGL engine.
Version v5.0:
• Redesigned the default wallpapwr with our official gamerrom wallpaper.
• Improved system performance and stability
• Added Xperia Weather
• Added new cpu settings app you can now adjust the speed of your device
• Fixed an issue with LTE data not auto configuring after first time boot
Version v4.4:
• Hot fixes.
• Fixed an issue with OTA Updates not fetching future updates
Version v4.3:
* The browser was finally replaced with Google Chrome this is our last change because the old browser randomly crashed and was super annoying!
Version v4.2:
* Fixed Browser crashes.
* Updated Android System webview.
* Fixed an issue with user on LTE data (ensure LTE is primary in settings).
* Added Google's New PDF Viewer.
* Made huge changes to the build.prop added stock values instead of mostly Lineage OS.
* Fixed audio quality and added stock audio drivers for a permanent fix.
* Rehauled the thermal engine config to stock config.
* Redesigned the OTA Updates application.
Version v4.1:
• Removed the security app for performsnce related issues.
• Improved browser progress bar
• Increased screen touch sensitivity
Version v4.0:
• Addes OTA Updates we will be now on sending os updates via OTA (Over-The-Air) so you dont have to keep downloading or checking for new updates constantly.
• In OTA Updates we added our thread so you can see whats new!
Version v3.4:
* Improved the browser and added new features in Advanced settings
* Added Time Zone Updater v8.1.0 to this build to update the timezone as time zones change whenever you travel out of your primary timezone.
* Re added back the Lineage OS Updater we have it there for experimentation purposes only.
* Re added back the Lineage OS Setup Wizard in case the user decides to not install any gapps!
Version v3.3:
• Removed GR Settings as it kept crashing on every boot of the device turning on.
• Added New Anti-Virus application to help battle viruses out.
• Imoroved System performance
• Removed My Network as it kept crashing
Version v3.1:
* Updated GR Setting with a new package name and design!
* Added new Application called "My Network" this will help you pick the best network and as well you can configure how it runs based on your preferences.
* Added Google Opinion Rewards to reward our users by answering Google based surveys and earn google play store credit to spend on applications from the app store.
* Updated Android System Webview to v74.0.3729.136
* Applied updates from LineageOS CM15.1 SRC.
Version v3.0:
• Updated GR Settings
• Fixed an audio bug that caused audio to fluxuate when listening to music at high volumes
• Removed our personal gapps
• Applied Updates from LineageOS SRC
Version v2.4:
• Many bugs fixes
• Added changes from LineageOS SRC
(No app updates were not upgraded in this update)
Version v2.3:
• Added GR Settings (customize how your OS runs)
• Added New Boot logo to Google Pixel XL
• New Bootanimation to match the bootlogo
• Fixed various of bugs
• Updated Security Patch Date: 2019-05-04
• Improved Browser (see below)
For Browser:
•Added New options in advanced this includes the following
• System app updates (gets the latest modified gapps update
• System Updates (check for system updates)
Version v2.2:
• Added Steam Link play your PC games on your phone to bring more media into your mobile gaming life!
• Replaced CM13 Browser with our dev Jelly browser
• Improved Graphics Performance
• Added an option to browser settings to check for system updates and the app can recieve updates via using Aptoide
Version v2.1:
•Final Change to Browser we replaced chrome with a new CM13 Mod Browser.
• Final Change: Updated the webview engine to google Android System Webview.
• Improved Audio Engine.
• Adjusted Dalvik to improve loading times.
• Possible Final Change: Replaced the OS bootanimation to a nexus logo bootanimation.
• Fixed slow downs when cpu throttles
Version v2.0:
• Updated OS Kernel
• Fixed a corrupted file while OS is booting
• Fixed an issue with random shutdowns when battery is below 40%
• Made some ZRAM imorovments
Version v1.6:
• New Audio Engine you will now notice a huge improvement with audio quality
• Fixed bug with fade in & out volume changes when listening to music at high volumes.
• Reverted browser back to chrome
Version v1.5:
• Added a new live wallpaper "Xperia Live Wallpaper" to give you more customization of your launcher and make it feel your playing a PS3.
• We took few days to make an open-source Chromium Browser that connects to our servers and optimized for Snapdragon Hardware & is now the default browser (Chrome Sync Not Supported).
• Removed GCS from the installer since the OS couldn't reconize it at all.
• Updated Google Search Go
• Improved Network connectivity
Version: v1.4:
• Restore old browser since chrome took alot of cpu usage and ram
• Restored Old System Webview as it caused OS to slow down and lag
• Removed LineageOS Setup wizard to since their was a present exploit that allowed users to bypass the Trust Lockout security system using a mysterious code. (Use our modded gapps pscksge to install the pico psckage with no google tts installed!)
• Improved OS rendering
• Improved HWUI
• Improved the ART Engine
Version: v1.3:
• Removed LineageOS Updates from Settings>About Phone
• Fixed black screen bug after ending calls & entering & exiting applications
• OS will now render UI & applications in the GPU by default to improve quality of the UI and games, can be turned off in "Developer Options" under Force GPU Rendering.
• Updated the Vendor Security image patch 2019-04-06
• Fixed Crashes on certain system applications
• Improved the Audio Engine and sound volumes
• Set dalvik heap size start to 16m instead of 8m
• Fixed Wireless charging bug that prevented the nexus 6 to charge on some models
Version v1.2:
• Added Google Connectivity Services
• Improved boot up times
• Added New Google Pixel 2 bootanimation
• Replaced the old Webview app with Google's Android System Webview application
Version: v1.1:
• Replaced CM15.1 Browser with Google Chrome (CANNOT BE REMOVED USING A GAPPS PACKAGE)
• Added Gmail Go (CANNOT BE REMOVED USING A GAPPS PACKAGE)
• Added YouTube (CANNOT BE REMOVED USING A GAPPS PACKAGE)
• Added Google Play Games (CANNOT BE REMOVED USING A GAPPS PACKAGE)
• Improved System Performance
• Fixed Touch Sensitivity when scrolling & playing video games
• Fixed framerate when playing a game requiring 3GB of RAM
• Added AdAway to give users the ability to block ads in all forms
Version v8.1:
Version v8.0:
Version v7.4:
Version v7.3:
Version: v7.2:
Version v7.1:
Version v7.0:
Version v6.0:
Version v5.4:
Version v5.3:
• Improved RAM Swap
Version v5.2:
Version v5.1:
Version v5.0:
Version v4.4:
• Hot fixes.
Version v4.3:
Version v4.2:
Version v4.1:
Version v4.0:
Version v3.4:
Version v3.3:
Version v3.1:
Version v3.0:
Version v2.4:
• Many bugs fixes
Version v2.3:
For Browser:
Version v2.2:
Version v2.1:
Version v2.0:
• Updated OS Kernel
Version v1.6:
Version v1.5:
Version: v1.4:
• Improved HWUI
Version: v1.3:
Version v1.2:
Version: v1.1:
If you love our project & want to help and support us you can choose to donate to us at anytime, however though it's not necessary to donate but i do appreciate each donation: https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=TCJKHJH9FG9SJ&source=url
Cyberdev 2010-2019 All Copyrights Reserved.
OS Testing Notice: This OS is certified by the developer "Cyberdev" to be 100% confirmed working and this confims it's genuine & that this OS has been 100% tested to pass it's inspection and is confirmed working, all builds that fail to meet developer expectation standards of a working build is denied to publish without a 100% working build. This means if a build fails such as the following:
• Failure to boot
• Failure to install
• Built-In Applications not functioning properly & causing them to crash
• Failure of improper installation of the modified gapps and more.
If any GamerROM build not coming from Cyberdev is NOT genuine and not officially supported by the developer and is an illegal port/copy of any GamerROM OS released by Cyberdev, and should be cautious of what fake OS you install!
