Root [ROM's] Project Butter Rush 4.1.2
K Rize
Okay, So it has come to my attention that me and a lot of other members have been having problems with this device, so I started a little project to see if I can help, and this is what I came up with.
I have 3 versions for you to try out
1. Project Butter Rush
This version has 6 market updates
I have to update it
https://docs.google.com/file/d/0B_DNsulDtL2_V2VYbHJUT1NMRGs/edit?usp=docslist_api
2. Project Butter Rush v1
https://docs.google.com/file/d/0B_DNsulDtL2_ZU16VDJiNHpCVW8/edit?usp=docslist_api
3. Project Butter Rush xSlim
https://docs.google.com/file/d/0B_DNsulDtL2_anlyZzN0VmtxaFk/edit?usp=docslist_api
I did it this way to hopefully suit your different needs, you can pick witch one works best for you!
Make sure you do a full system wipe before flashing
The apps in the app drawer, the themed systemui, and the option to use a different launchers; Apex, Nova, Trebuchet
Hey, so i put together a theme for v1. Tell me what you think :)
Screenshots
Butter Theme
Also, the updater script for v1 thinks it's xslim :p
Yes, I forgot to edit the updater script
But the theme looks great, really like the toggles :thumbup:
So, when will you make a fully themed ROM?
I would love to see what you come up with
Also, i think you know this, but for people who don't :what:
if you theme your whole phone, you can turn it into a ROM :D
Quick How-to Guide:
make a cwmr backup of it,
then take the system.ext4.tar.a and extract the system folder from it with ZArchiver.
Then take the META-INF folder from any of the above Roms, and the boot.img from a stock jb kernel.zip or Animania's work.
Zip all three and you will have a themed flashable ROM
Zip should be two folders (System & META-INF) and the boot.img
I hope this helps you and others...
Looking forward to see more of your work
FYI, All of the work I do on this phone, is done on the phone, and not a computer
So, if there is a will, there is a way :thumbup::D
I'm playing with a few things, but I'm not super familiar with touchwiz and it's slowing me down in some areas
Yes I know what you mean, one false move, and it goes loopy
I had the sgs2 Seclauncher.apk working, then I started changing more stuff around, got into a loop, reflashed, now I forgot how I did it, it's very frustrating
Are the apps such as camera, phone, and messaging actual android stock or the stupid touchwiz stock with themed icons instead?
Cool :thumbup:
I won't be updating these, so your mods should work with no problem
They are only stock with different apps and the latest kernel and systemui, it's other things I wanted to add, but they are gonna have to wait for the kRom (blu 4.1.2) while I'm trying find a way to get us to 4.2 or CM
Hey sorry I couldn't test this for you a while back but wow nice! This looks promising I'll try it out when I get my rush back at home. Are those stock apps I see?
OMG I LOVE THIS ROM!!!! its faster then stock for sure. the music never sound better. but i have to say about dsp manager is good but it doesnt allow the compression at the same time as the equalizer like the awesome beats in Party Time JBS v2.4 did. but other than that great rom :D
Does trebuchet have a stock jelly bean theme?? I moved apk to system/app and set permissions to rw-r-r. It forces close
Did a reset and fixed permissions. All is well...seems smoother than nova that i am using..Question?? Does this launcher have themes??
If you have xposed framework installed you can download icon themer app and you can use any icons from the playstore.
