Root Root help.
Gvn96
So I unlocked bootloader following Scotty's tutorial and proceeded to run AAHK.
Followed all of the necessary steps as per the instructions and then It tells me (after downgrading the RUU) to run AAHK again to root it etc.
It fills the progress bar, then says some shit about failing to do something with the radio, i dunno.
TL;DR - I'm on a black screen now with nothing loading. WTF Did I do wrong, how do I fix it?
Going through AAHK for a 4th time, seems it wasn't booting the ADB.
Kept getting the following
adb server is out of date. killing...
ADB server didn't ACK
* failed to start daemon *
error:
* daemon started successfully *
Something along those lines -
except when I first did it ,
It only wrote that once - then froze up.
So maybe its working this 4th time through, we'll see.
update.
It says it 'finished' that time around,
told me to press any key to continue.
So I did
Now at black screen again.
Nothing here.
[Select and press Enter]1
/sdcard/PD98IMG.zip: Permission denied
rm failed for /sdcard/PD98IMG.zip, Permission denied
26.03.02.26_M
goldcard.img
goldcard
Linux version 2.6.32.21-gf3f553d (htc-kernel@and18-2) (gcc version 4.4.0 (GCC) )
#1 PREEMPT Thu Oct 28 13:24:11 CST 2010
major abra-cadabra going on, please be patient.....
property service neutered.
killing adbd. (should restart in a second or two)
--secu_flag off set
--cid set. CID will be changed to: 11111111
--sim_unlock. SIMLOCK will be removed
Section header entry size: 40
Number of section headers: 44
Total section header table size: 1760
Section header file offset: 0x000138b4 (80052)
Section index for section name string table: 41
String table offset: 0x000136fb (79611)
Searching for .modinfo section...
- Section[16]: .modinfo
-- offset: 0x00000a14 (2580)
-- size: 0x000000cc (204)
Kernel release: 2.6.32.21-gf3f553d
New .modinfo section size: 204
Attempting to power cycle eMMC... OK.
Searching for mmc_blk_issue_rq symbol...
- Address: c02a9e00, type: t, name: mmc_blk_issue_rq, module: N/A
Kernel map base: 0xc02a9000
Kernel memory mapped to 0x40000000
Searching for brq filter...
- Address: 0xc02a9e00 + 0x34c
- 0x2a000012 -> 0xea000012
Patching and backing up partition 7...
Error opening copy file.
I- NORMAL ERROR HERE -I
patience - rebooting
error:
/sbin/sh: /data/local/tmp/gfree: not found
/sbin/sh: /data/local/tmp/flash_image: not found
board_spade.disable_uart2=0 board_spade.usb_h2w_sw=0 board_spade.disable_sdcard=
0 diag.enabled=0 board_spade.debug_uart=0 smisize=0 userdata_sel=0 androidboot.e
mmc=true androidboot.baseband=26.03.02.26_M androidboot.cid=CWS__001 androidboo
t.batt_poweron=good_battery androidboot.carrier=ATT androidboot.mid=PD9812000 en
able_zcharge=1 androidboot.keycaps=qwerty androidboot.mode=recovery androidboot.
serialno=HT18GT203813 androidboot.bootloader=0.85.0024 zygote_oneshot=off kmemle
ak=off no_console_suspend=1
cp: can't create '/system/lib/modules/bcm4329.ko': No such file or directory
push: tools/afr/system/app/Superuser.apk -> /system/app/Superuser.apk
push: tools/afr/system/bin/su -> /system/bin/su
2 files pushed. 0 files skipped.
2807 KB/s (609587 bytes in 0.212s)
su
S-OFF, ROOT and Clockworkmod recovery complete
Be patient - installing updated radio and AAHK ENG Hboot...
Starting update process....
erasing 'cache'... OKAY [ 0.142s]
finished. total time: 0.142s
Be patient - sending update ...
sending 'zip' (11650 KB)... OKAY [ 1.911s]
writing 'zip'... INFOsignature checking...
FAILED (remote: 12 signature verify fail)
finished. total time: 3.386s
rebooting...
finished. total time: 0.157s
error:
************ Process complete **************
Press any key to continue . . .
- Black screen again...
Going to try and make a bootable ubuntu disc and see if I can run AAHK through there for better results, *Crosses fingers*
glad you got it working. your thread is not pointless,it does in fact help re-enforce what we always tell folks- that the process typically goes much smoother on a mac(irony :eek:) or on linux.
it seems difficult to set up the "pc envorinment" to deal with the complexity of the aahk tool with windows due to driver issues,and the potential for other things to interupt communications with the phone.pda net,easy tether,htc sync,even itunes can all cause prollems.
may consider updating back to att newest firmware(even if you intend to flash a custom rom). use these directions: http://androidforums.com/inspire-4g-all-things-root/632116-firmware-update-rooted-inspire-4g.html
youll also find alot of good info in the DHD ATR subforum,as the DHD and inspire 4g are basically the same hardware. just holler if you have any questions. :)
