Root ***Rooted...Need help with Bootloader, Roms & Overclocking***
Hello to everyone who is seeing this..I am new to Android modifying and need help..I have already rooted my Nexus 7 (2012)..now I wanna customize it..I need help with unlocking the bootloader, changing the rom, kernel and overclocking..I have found a lot of info and help in the threads on here..but I get lost & confused when I try to follow the directions in the threads on how to unlock the bootloader, changing the rom, kernel and overclocking..So I beg someone to please help..I think texting would be an easier way to communicate then P.M..here is my #<moderator redacted>..Thanks for ur time and consideration..Reggie
Use wugs nexus root toolkit. Its an easy GUI based program that does everything you need for unlocking boot loader etc.. Then you can follow the direction that come with the ROM of choice for installing a ROM.
Be sure to copy anything you want to keep from internal storage onto PC first before unlocking via Wugs toolkit. Unlocking will completely wipe the device.
