D
Deleted User
Guest
Hi there. Can anyone help.
I have an HTC Desire which I rooted about 2 weeks ago hoping to free up some internal memory
Everything seemed to be running fine until I noticed that I was starting to get low on internal space and now I'm getting a message that states that I can't install apps because there is not enough memory. I installed and ran Move2SDenabler and when I open App2SD, I can transfer most apps to the SDcard. Same thing when I got in the phone settings under Applications. I can transfer most apps to SD and the settings state that the Apps are on my SDCard. So I trasferred everything I could to my SD card, but when I open up the Disk Usage App, if I look at the APP storage tab, I am using 147 MB of data of which 85 MB is used by applications, 44 MB for System Data and only 18 MB of free space. Under the same app, if I open the Storage Card tab, the majority of space is used up by maps,music, video, and pictures and I have 24 GB of free space, yet I don't see any applications. There is definately something I am not getting about this rooting thing.
How can I really move all the Apps and data to my external SD Card?
By the way I am using a Mac to sync. Could this be part of the problem?
