Root Rooting woes
I been trying to do this all evening and all I am getting is silently mocking laughter of my ineptitude when I do this.
I am running Win 7U 64
I think I have tried everything.
1. I disable the driver signing from the Advanced Boot Options
2. I am running Odin with XP SP3 compatibility enabled.
3. The phone gets detected by my system.
It starts the process, but when it gets to system it fills up about half way and stops. I have left it going for 30+ minutes and still the same thing
The phone never resets or shuts down. No weird messages on the phone itself.
I have tried VitrualBox that is XP SP3 on a Linux Mint 10 host, but as soon as it tries to start, the VM restarts.
Any other ideas or suggestions.
I want to thank you all in advance.
Here is what Odin is saying when I do it. I have tried just using the OPS and PDA themselves with same results
Code:
Download Start...
<0> Create File...
<1> StartThread Detected : 1
<2> StartThread Detected : 0
<3> StartThread Detected : 0
<4> StartThread Detected : 0
<5> StartThread Detected : 0
<6> StartThread Detected : 0
<7> StartThread Detected : 0
<8> StartThread Detected : 0
<1> setup connection...
<1> odin mode.. check plcatform verification.
<1> START!!!
<1> check download environment.
<1> amss download..
<1> 1/3 Finished.
<1> kernel download..
<1> 2/3 Finished.
<1> system download..
Dark put the one package into pda and ignore all errors then press flash. i had the same problem. i began to mess around and this way fixed it.
