S Planner settings help
reaperman
Do any of you s planner users know how to access the settings on the calander? I havent been able to find them. The one setting I want to change is the default event length. Each time I add a event, it automatically adds a one hour event time. I want the default event time to be 0, not one hour. Before the 4.2 update, I could just make the event length the same time as the starting event time. But when I try to do that now, the event length still shows one hour. I use S planner for scheduled drop off times for my business. So any event is normally a short time duration. And a ending event time isnt necessary to me whatsoever. Thank you.
