Natedoggg777
I'm having trouble trying to fix my sister's captivate. First off, let me tell you all details before I tell you the problem. A couple of months ago my sister got a used phone, samsung captivate, from her friend and well she was using it and everything was well until about a month ago she started having problems with it. Then out of no wheres it stopped working, because it would pop up with these annoying notifications that everybody knows of. Unfortunately lol... And another frustrating yet annoying problem is every time I take out the battery and put it back in it would turn on automatically. So, I tried doing everything possible that I can think of to work the phone, but nothing has helped. I have finally bought a jig and FINALLY got it into DLM, but I was messing around because I wanted to flash stock it back to the original firmware to see if it worked, but I didn't see a progress bar on Odin or my captivate. So I unplugged it and now it has the "phone-computer with a yellow triangle" screen... i tried to put it back into DLM with the jig that I bought, but no luck because of every time I take out the battery and plug it in it turns on automatically.
p.s. I am new to android and I do not know what the firmware is on the captivate, so please don't ask me, but I would like to acquire all the valuable and necessary info that you can give me. Thanks and please reply asap!!!!
