Samsung Galaxy Note 1717
jw4669
Hi everyone i am having some serious problems with my phone. I tried my first custom Rom. It went well. Then i decided i wanted to try another one That did not go so well. After playing around in clock work mode. I ended up becoming frustrated and formatted several area's in clock work mode. Now my phone won't load. However i can still get into clock work recover mode. However i don't know what i can do from there. Can any one give me a step by step. I did check out a sight that told me i can go to boot loader and flash my stock Rom that came with But every sight i have been to is a scam i go to the sight and it is not the download they promised. Or can i flash another rom from my sd chip. Please help. The phone cost me 200.00 and i can't afford to buy another.:confused:
Go to SamMobile Firmwares and put in the model NUMBER (1717) and see if one of those ROMs is for your tab. (It has to be the same one your tablet was made for.) If there is, you can flash it yourself. If there's an orange symbol at the end of the line you can use Kies to reset it. otherwise you'll have to use Odin.
I found and downloaded the stock zip file for my device. The problem is when i was using clock work mode. I formatted/system/cashe/data/storage. As a result i wiped my whole directory. Now even after i installed the latest Samsung usb drives my computer won't recognize my galaxy note. So i can't flash another Rom. Question if i load the stock Rom onto a sd mirco chip can i load it from there?
