Samsung Galaxy S6 Official Specs
kate
Dreaming of Bugdroid.
Moderator
Aug 14, 2013
6,232
5,795
tingmobile.com
Below are the specs for the new Samsung Galaxy S6 smartphone running Android Lollipop with TouchWiz.
Processor
Samsung Exynos 7 Octa – Four cores run at 1.5GHz and four at 2.1GHz
64-bit processor built to a 14nm process
Memory and storage
3GB of LPDDR4 RAM
32GB, 64GB or 128GB of UFS 2.0 flash memory
Wireless
LTE category 6 modem (300mbps download)
802.11ac MIMO 620mbps
Bluetooth 4.1
Cameras
Front: 5-megapixel, f/1.9 lens and real-time HDR, wide-angle selfie
Rear: 16-megapixel, f/1.9 lens (34 per cent more light reaches the sensor than on the S5), smart optical image stabilization, launch by pressing and holding the home button in 0.7 seconds, tracking AF
Battery capacity
2550mAh
The phone has a fast-charge mode that gives it enough power for 2 hours of HD video playback or 4 hours of “normal” use in 10 minutes.
Supports Qi and Powermat for wireless charging.
Screen
5.1 inch Quad-HD Super AMOLED display
1440 x 2560
Speaker
Bottom-mounted, 1.5x louder than the Galaxy S5
Amplifer built in for best quality sound
NFC
Compatible with most payment systems – MST, NFC and Barcode with magnetic stripe storage too
Security
Samsung Knox
Find my Mobile, reactivation lock, remote wipe, remote ultra power saving mode to keep the phone running and trackable for as long as possible
Dimensions and weight
143.4 x 70.5 x 6.8mm (5.65 x 2.78 x 0.27 in), 138g
More info:
http://phandroid.com/2015/03/01/samsung-galaxy-s6-official/
http://www.forbes.com/sites/ianmorr...nd-s6-edge-here-are-the-full-confirmed-specs/
BEST TECH IN 2023
Smartphones
