Help San Francisco 2 bootup problem
Hi,
Forgive my ignorance, I'm a total newbie at android, this one being my first.
Got the phone a couple of days ago, decided against faffing about to get it unlocked, so paid a shop a tenner, job done. When I got the phone, it worked fine, just before I took it to the shop, it got stuck on the android logo, flashing and vibrating intermittently. Gave it to the shop and they unlocked the phone no problems.
So, phone worked well, once I'd figured out what my carrier setting were! (on three), charged it off the PC, unplugged and it was back at the flashing android.
took out battery, replaced, still the same...
eventually I took out the SD card, sim and battery, left it unplugged for about 5 mins, replaced the battery and restarted. Phone worked.
Put sim and SD back in, still worked and everything was dandy.
Installed Endomondo app yesterday, install went ok, no sign of problems. ran it to log in, again, no problems.
So, used it this morning, it ran for about a minute then stopped tracking. I noticed after only one music track had played, then silence.
All I got from there is intermittent vibrations. A quick google and turns out it's out of charge, though it had been on charge all night. Plugged it in.
since then all I get is the return of the flashing android+buzz. I've had the battery out, the sim out, the sd card out, restarted in every imaginable combination, still the same.
Also, if I connect it to the PC, the PC does not see it.
Any help would be appreciated, it's probably something simple that I'll feel stupid for not knowing, but hey every day's a school day.
Thanks in advance.
Also, can't get into FTM either (not that I'd really know what to do if I did)
I think it'll be going into the shop tomorrow to see what they can do.
OK, took it to the shop, they can't get hold of the software to sort the phone for another 4 weeks.
At present I have a phone that doesn't charge and when I connect it to a PC (win7) it says the phone isn't recognized.
Is there a way of power + Up/Down to install a fix from the SD card?
thanks
Send it back to where you bought it. Then use the Modoco forum to unlock it yourself. Just take your time and you`ll be ok. I think in 4 weeks time the shop will have another excuse ready.
