yodelyfish
I purchased the Moto g 4g version about 2 weeks ago and I love it. Everything about the phone is great. Unfortunately the other day I dropped the phone mabye about 2 ft. and it must have landed on the perfect spot on the corner because the screen spider cracked in a heartbeat. I was surprised how easy it was for the screen to shatter. I know its glass but still (should've had a cover anyways). I am going to get this phone replaced with another of the same version ( I chalk it up to bad luck) straight from the Motorola site so I can get a shell for free with it for some added protection.
Before I do that though, I would like to weigh my options for repair. My phone is not covered by Motorola's new "fix your screen for free once" plan announced about a month ago because I bought it through amazon and not the motorola site directly. The phone works fine, the screen is just cracked. The cracked portions are just fine to touch and use as well, so I believe the digitizer is fine. But before just buying some parts I have a few questions.
1. I own the Motorola Moto G 4g model. I'm assuming its exactly the same as the original moto g in terms of dimensions, but just to be sure: If I find a glass lens online for the Moto g, will it work for my Moto g 4g?
2. If I choose to do the repair option, will this diminish or remove the phone's abilitiy to remain waterproof (with its protective coating)? Not sure if the 3rd party glass lens would have the coating.
3. If anyone has any experience with repairing screens such as this (this will be my first time), what do you suggest? Was it difficult? Any special precautions that need to be taken?
Thanks for the help everyone
