Accessories Screen protector for camera lenses
Do any of the full body kits from seidio, best skins ever, zagg, phantom skinz, ghost armor, xo, etc. provide cut outs for the two camera lens areas?
If yes, how does the camera work after putting those on? Blurry? Distorted?
Thanks!
I think a lot of people are misunderstanding the cameras. The lenses aren't exposed to the elements. They both have glass over the top. Not sure how easily scratched the glass is though.
I figured a quick fix to the scratches to the glass would be applying one of those products, but don't know how the image quality is affected.
the glass can be scratched. i know this from first hand experience :(
not sure how easy it would be to replace the outer glass element, especially as the phone just came out the chinese parts websites haven't had time to draft up replacement parts.
you can actually buff out minor scratches in glass using cerium oxide or jeweler's rouge along with a rotary tool - but mine's not bad enough to warrant that yet.
not sure how image quality would be affected.
