Any way to swap external sd to internal? Ive tried exposed. And xinternalsd mod. But google play wont work after. Any ideas? Can i rename a couple of init files like did for huawei primia?
I think that's impossible, unless you create what is known as a swap, which isn't switching the sd cards, it basically adds more space to your internal by making a part of your external look like a part of it.
