For note 3 thy 've launched lollipop [emoji324] just chk software update in settings via wifi r mobile data onces..[emoji144]
That Note 3 should have received Lollipop update by now, I think that's a non-carrier version. One thing it might be, are you using it in the region it was intended for, like if you bought it in Asia, it might not receive OTA updates when used in Europe. You could try using Kies with a PC, see if it will update that way.
Yeh, there can indeed be some third-party things that might break, like certain BT devices, so well advised to check compatibility before updating if it is something important that you use. It might be that the apps need to be updated.
If OTA hasn't offered any upgrades. Install Kies on your PC, plug phone in and see if that offers anything. Many Samsungs are made in Vietnam, no problems there.
Merged duplicate threads
That only causes confusion amongst members, hence the merge.Dont merge my threads please cuz I posted them in three different forums
