A coworker brought me his Nexus 7 (2012) because it wouldn't charge or turn on. I have read all about these tablets failing to charge, and about how holding the power button for at least 30 seconds usually fixes the issue, but that doesn't work on this one. When I plug it into my computer with a micro-USB cable, nothing happens until I start holding the power button. When I hold the power button, the tablet doesn't do anything, but the computer suddenly dies. It doesn't freeze or go through a shutdown sequence; it just turns off. When I plug the cable into an AC adapter, the tablet still won't turn on. Nothing seems to be getting hot; no blue smoke or funny smells. I removed the back cover, and the battery looks perfectly normal. The only thing that looks a little weird is the micro-USB connector; it looks a little bent. I think that might be the problem; I think it might be short-circuiting and grounding something that's not supposed to be grounded. Does anybody else have any suggestions? I just wanted to get some advice before spending $30 on a part.
