I am truly having the month from hell for all things computer. I am about to chuch every electronic device I have out the window T_T
Anyway,
I was hoping someone could spare a few moments to help me out with a problem Ive run into with my Galaxy Note 8.0
I was very anxious to get kitkat, so I decided to root and load CM11 kitkat.
I had already Rooted using Odin, and everything was working perfect. But I got greedy and wanted to flash a rom so I could have KitKat.
I followed the following guide:
Update Galaxy Note 8.0 N5110 To Android 4.4.2 KitKat via CM11 Nightly–How To | True Android | #1 Custom Android Resource
But it wouldn't take:
"-- Installing: /external_sd/cm-11-20140222-NIGHTLY-n5110.zip
Finding update package. . .
Opening update package. . .
Installing update. . .
set_metadata_recrusive: some change failed
E:Error in /external_sd/cm-11-20140222-NIGHTLY-n5110.zip
(Status 7)
Installation aborted."
I thought it was very odd to Flash a rom using a Nightly as Im under the impression those are for CM updates, but ANY search I did for flashin a fresh CM11 for Galaxy Note 8.0 n5110 all pointed to the guide.
I tried to restore, but once it restores and reboots, an endless flood of popups come up indicating that one app after another has stopped working. Obviously I didn't backup right.
And just in case it makes a difference, I tried to install the Nightly from external sd card (as indicated in the quoted process log).
I feel very very frustrated and can't figure what Im doing wrong to cause these issues, but I would deeeeeeeply appreciate some help. I know im all over the place on this forum and I apologize deeply, but like I said, Im having the month from hell so please be patient with me.
Anyway,
(Status 7)
