I unlocked boot loader n rooted my Xperia S.
after following a set of instructions, i happened to copy a zip file to my sd card and then booted into the recovery mode of a kernel. When i tried to install the rom ( which was in the zip file i copied before ) it showed me a success but when it comes to booting back in the normal mode, it doesn't happen. The kernel boot shows up instead.
Now all i can do is enter the recovery mode. Bummer !!
I can't even copy other roms into the sd card cause i can't boot my device normally hence, there is no way i can access my sd card either.
Somebody help fast !!!
